Deepak_Mehta
Mar 03, 2021Aspirant
Speed Issue
Hi All, I have internet connection of 300 MBPS upload and download both for RBR850 , but still speed is not increasing more than 100MBPS Is there any other settings to be done on the router. ...
Deepak_Mehta
Mar 04, 2021Aspirant
What Firmware version is currently loaded? ( Firmware Version V3.2.17.12_1.4.14)
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? (dbc connected with fiber optic and from there one output cat6 connected to RBR850)
Are you testing with a wired or wireless device? i have checked on both wired and wireless
Be sure your testing over a wired PC connection. (Checked on same)
Make sure your wired network adapter is supporting of 1000Mbps and not 100Mpbs. Older network adapter cards were rated for only 100Mpbs. ( Yes i had 1000MBPS connection)
Be sure your using good quality LAN cable. CAT6 is recommended.(Yes using manufactured cable)
I am getting proper speed on my old device.
Deepak_Mehta
Sharing Net speed on old connected devices
