Xelbak
Oct 22, 2021Aspirant
Speed issues with my orbi
Hello everyone! I recently purchased an Orbi AX4200 wifi mesh system Model # RBR750 with two satteltites model #RBS750. I have gigabit interenet but those speeds don't seem to carry through to the...
Oct 23, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor or SPC enabled on the RBR?
You may need to factory reset the system and power the system OFF as well.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150287/highlight/true#M21560
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150391/highlight/true#M21575
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150417/highlight/true#M21579
Xelbak
Nov 15, 2021Aspirant
V4.6.5.14_2.0.54
No idea where the ONT box is as I'm only a tenant in this house. it's a spectrum gigabit modem I know that lol
I did factory reset and reboot my orbi system but that showed no changes in speeds
2,031 sq ft however I live on a lake and my room is located right off the water which is down some stairs once you walk out the back door. So it's probably a little more than that.
I can't see my distance between them being that much more than 30-35 feet.
2.4ghz is on channel 2 and 5ghz is on channel 36. messing around with the channels hasn't seemed to yeild any positive results.
Yes, maybe 3 or 4 that I can pick up when I'm upstairs in the house.
No.
