Chuck_M
Nov 15, 2019Mentor
Speed Test acting odd
I have noticed the speed test built into the Web GUI acts odd these days. Uner the Advanced Tab, Setup and QoS Setup: When you click on TAKE A SPEEDTEST... it appears to produce a speedtest v...
ekhalil
Nov 23, 2019Master
Chuck_M wrote:Update: The speedtest in the web gui only shows the results of a speedtest taken 2 days ago. The speed reported did not match the last speedtest taken on the orbi app. When clicking on TAKE A SPEEDTEST it still instantly shows results and date of two days prior.
Can anyone else please check their webgui to see if this is just me or a system issue
For me, it takes 15-20 seconds for the result of the spped test to come out, exactly as it always did.
KMDonlon
Nov 24, 2019Virtuoso
Using the speed test appears to activate some type of QOS settings.... My wifi slows down tremendously after using the speed test and there appears to be no way to turn QOS off or on currently in the GUI
