Chuck_M
Nov 15, 2019Mentor
Speed Test acting odd
I have noticed the speed test built into the Web GUI acts odd these days. Uner the Advanced Tab, Setup and QoS Setup: When you click on TAKE A SPEEDTEST... it appears to produce a speedtest v...
Chuck_M
Nov 16, 2019Mentor
Update: The speedtest in the web gui only shows the results of a speedtest taken 2 days ago. The speed reported did not match the last speedtest taken on the orbi app. When clicking on TAKE A SPEEDTEST it still instantly shows results and date of two days prior.
Can anyone else please check their webgui to see if this is just me or a system issue
ekhalil
Nov 30, 2019Master
Chuck_M wrote:Update: The speedtest in the web gui only shows the results of a speedtest taken 2 days ago. The speed reported did not match the last speedtest taken on the orbi app. When clicking on TAKE A SPEEDTEST it still instantly shows results and date of two days prior.
Chuck_M I've just saw the same issue, that the speed test shows the results of the speed test taken 2 days ago.
When this happens in the web GUI, the Orbi app just times out when running a peed test.
Nothing helped to solve the issue except a factory reset. Very wierd issue.
- Chuck_MDec 01, 2019Mentor
Thanks for letting me know... glad it isn't just me.
So....
- Remote access using Orbi App
- Device Naming
- Speed Testing
I wonder when we will start to see movement on some of these issues.
Any tribal knowledge out there on when the next firmware release is?
