Hilgemoon
May 17, 2020Aspirant
Speeds on my ATT Wireless network SLOWER with Orbi AX600?
Hi, all, I have a mess of smart home equipment and with the pandemic plus my son being home, my wifi has noticeably slowed down (from getting regularly 2-300 mpbs to around 120-150 usually), plus hav...
May 18, 2020Guru - Experienced User
ATT devices are notorious for their "modem only" mode not functioning properly.
What you could try?
1. put the att device back in router mode.
2. disable the wifi on the att device
3. put the orbi in AP mode (access point)
It disables some features of the orbi device but could allow you to hit the speeds you're paying for.
sadly, att's poor implementation has caused issues before. Some can get bridged mode working properly but others have to resort to using their Orbi's as just AP's.
Hilgemoon
May 19, 2020Aspirant
Oh and wait, I think I understand what you're suggesting. Let the ATT device be the router & modem, but the Orbi devices will provide the Wifi signal as APs? In AP mode, what functionality would the Orbi lose? I was hoping to take advatage of some of the Armor security SW when that drops and/or install a VPN, I'm guessing that's a non-starter. What about the actual Wifi 6 function I purchased it for, of being able to route to many devices at once?
- plemansMay 19, 2020Guru - Experienced User
You do lose some features in AP Mode.
https://kb.netgear.com/000061277/Disabled-Features-on-the-Orbi-when-set-to-AP-Mode
AX and lan routing would all still work fine though.
Armor wouldn't work because the att device would be running all the routing features.
