portlandp
Jan 07, 2021Aspirant
speedtest not working after adding additional satellite
I purchased a router/satellite combination on 12/31. On 1/5, I purchased an additional satellite to help with coverage upstairs. The satellite appears to be working (the "network map" option on the a...
Jan 07, 2021Guru - Experienced User
What Firmware version is currently loaded? Be sure FW is same on all units.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
portlandp
Firmware: v3.2.16.22_1.4.9 (according to the app)
I don't know how to check the firmware on the satellites or anywhere else that isn't visible by clicking the "About" tab on the app.
Modem = Netgear CM1000
Home is 3,000 sq. feet
Satellites are both at least 30 feet away from the modem.
I've heard that a factory reset of the router is the way to go if I want to get the speed test to work on the app. Do you agree?
- FURRYe38Jan 07, 2021Guru - Experienced User
Last time I check, the speed test in orbi app and on RBRs web page worked for me.
If you haven't reset since last update, lets try that on the RBRs web page under Advanced Tab/Administration/Backup with a wired PC and web browser. Then power OFF the ISP modem for 30 seconds then back ON. Walk thru the setup wizard. No need to add the RBS during this. After you complete the setup wizard, go into the QoS section first and run a speed test there.
