huser
Oct 17, 2024Follower
Split ssid 2.4 and 5
Hi , planning on buying orbi 750 for a good deal . But I am wondering if I can make two ssid for 2.4 and 5 ? Everything I read it says it can’t do it but they are also more than a year old posts . An...
Oct 17, 2024Guru - Experienced User
the 2.4ghz still works fine even combined. I've been using mesh for over a decade and the apps/support have gotten much better. I haven't ran into anything in years that I had to have the networks separated to get them to connect to the 2.4ghz.
I wouldn't worry about it to much.
Plus if you do run into issues, there's easy ways around it.
