skeelo
May 09, 2020Luminary
Spotify intermittent drops
Running an Orbi RBR852 with an extra satellite. From time to time Spotify with drop the connection on my TV after installing. I did not have this issue when running my ISPs router (2.4 and 5 disabl...
- May 17, 2020Ended up hard wiring the TV.
Would be great if you could break out the 2.4 and 5ghz frequencies if you wanted to or force a device to a specific frequency.
There is already a toggle to turn internet on and off at the device level. Seems like adding a toggle or option for 2.4, 5, or both at a device level should be doable.
May 10, 2020Guru - Experienced User
disabling the wifi doesn't disable the routing features of a router. if you're running a centurylink modem/router and the netgear you'd be in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
here's an article on fixing that.
