skeelo
May 09, 2020Luminary
Spotify intermittent drops
Running an Orbi RBR852 with an extra satellite. From time to time Spotify with drop the connection on my TV after installing. I did not have this issue when running my ISPs router (2.4 and 5 disabl...
- May 17, 2020Ended up hard wiring the TV.
Would be great if you could break out the 2.4 and 5ghz frequencies if you wanted to or force a device to a specific frequency.
There is already a toggle to turn internet on and off at the device level. Seems like adding a toggle or option for 2.4, 5, or both at a device level should be doable.
May 10, 2020Guru - Experienced User
What mode is the modem working in? Modem only or router mode. That modem has a built in router and wifi. Just disabling the radios on the modem won't help with NAT issues. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Also if your other apps and services are working and only Spotify isn't, possible app issue here or something with the TV isn't working right.
skeelo wrote:Running an Orbi RBR852 with an extra satellite. From time to time Spotify with drop the connection on my TV after installing. I did not have this issue when running my ISPs router (2.4 and 5 disabled now) and do not have this issue when running other web services (e.g., Netflix, Disney+). I have CenturyLink fiber and test at 930 or so up/ down at the Orbi and 350-450 wirelessly on my Mac and iPhone.
The TV looks to be connected to the 5ghz signal on the RBR and there is an RBS on the upper level also. I was originally thinking the TV was switching between the RBR and RBS but accoring to the app that is not the case.
I ran a Wifi scan on my Mac and changed 2.4 to channel 11 and 5 to channel 36 per its recommendation.
Anyone else having this issue?
skeelo
May 10, 2020Luminary
Thanks for the suggestions. I can set the modem to transparent bridge but going to try the DMZ/ Exposed host route first as it's easiest and I do not have to deal with CenturyLink tech support on a Sunday...
Thought the issue could be with Spotify,however, when hooked up to the CenturyLink modem/ router WIFI I do not have this issue. I assume it has something to do with the RBR/ RBS, device switching between points, switching between 2.4 and 5 ghz, and perhaps how much the Spotify service buffers.
- FURRYe38May 10, 2020Guru - Experienced User
Possible behavior with the service...
Try AP mode on the Orbi AX as well.
