skeelo
May 09, 2020Luminary
Spotify intermittent drops
Running an Orbi RBR852 with an extra satellite. From time to time Spotify with drop the connection on my TV after installing. I did not have this issue when running my ISPs router (2.4 and 5 disabl...
- May 17, 2020Ended up hard wiring the TV.
Would be great if you could break out the 2.4 and 5ghz frequencies if you wanted to or force a device to a specific frequency.
There is already a toggle to turn internet on and off at the device level. Seems like adding a toggle or option for 2.4, 5, or both at a device level should be doable.
skeelo
May 10, 2020Luminary
Thanks for the suggestions. I can set the modem to transparent bridge but going to try the DMZ/ Exposed host route first as it's easiest and I do not have to deal with CenturyLink tech support on a Sunday...
Thought the issue could be with Spotify,however, when hooked up to the CenturyLink modem/ router WIFI I do not have this issue. I assume it has something to do with the RBR/ RBS, device switching between points, switching between 2.4 and 5 ghz, and perhaps how much the Spotify service buffers.
May 10, 2020Guru - Experienced User
Possible behavior with the service...
Try AP mode on the Orbi AX as well.
