Troxbury's avatar
Troxbury
Initiate
May 05, 2021
Sppeed being throttled by the Netgear Orbi WiFi 6 mesh system AX6000 (RBK852)
I have just installed a Netgear Orbi WiFi 6 mesh system AX6000 (RBK852) to take advantage of the higher transfer speeds. I upgraded my network to 1Gb when I connect to my providers router I get betwe...
  • Troxbury's avatar
    May 05, 2021
    Problem Solved. I was using an old ethernet cable. When I changed it things worked.
