ljmunster
Sep 28, 2022Aspirant
SSID name change no internet connection Orbi 850
We lost internet service last night so I rebooted all of my equipment. I could not get the Orbi router to work properly so I did a factory reset. Upon doing this, the router worked fine as long as ...
ljmunster
I am actually just trying to change the credentials to what I have been using before the reset.
I have tried using the app on my iphone and ipad as well as through the browser on my laptop.
It seems to be working fine with default sign in credentials but when I change the ssid and password, I lose internet.
CrimpOn
Sep 28, 2022Guru - Experienced User
When the Orbi SSID is changed, the radio system restarts and any devices currently connected to the Orbi no longer have a WiFi connection. What should happen is the device notices that WiFi dropped, looks for a WiFi SSID that it knows the password to, and connects.
Once the WiFi SSID/password has been changed, does it appear on the list of available WiFi systems?
- ljmunsterSep 29, 2022Aspirant
UPDATE
I have connected to the Orbi 850 router with my laptop. All of the 2.4ghz devices appear to be connected and functioning.
However, my 5ghz devices (laptop, phones, ipad) will not connect. I can see the network listed but the devices wont connect. In fact, my laptop says connected but no internet.
While I am connected directly through ethernet, my laptop is working fine.
