ljmunster
Sep 28, 2022Aspirant
SSID name change no internet connection Orbi 850
We lost internet service last night so I rebooted all of my equipment. I could not get the Orbi router to work properly so I did a factory reset. Upon doing this, the router worked fine as long as ...
Sep 29, 2022Guru - Experienced User
When and if you change SSID, it's best to turn OFF or disable devices wifi radios first. Then make the change on the RBR and ensure it populates to the RBS. Once the system is stable after the change, then enable 1 wifi device and have it scan for the SSIDs. Should see the new SSID, have it connect.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
