tuxbox78
Jan 18, 2022Aspirant
(stability) problem with RBK853/its RBS850 satellites web interface
Hi, i have a strange problem with (only) one of my RBS850 satellites. One (and always just this same one) "looses" its web interface after a few days, but it seems its wifi still works as normal and ...
tuxbox78
Jan 19, 2022Aspirant
Yes, acutally i have done a factory reset as otherwise before i also had problems with the integrated speedtest. Those are gone now, but the "vanishing" web interface of this RBS850 Satellite always was and stayed the same.
Regarding beta-firmware .. i usually am the first to use and test beta stuff, but this setup is key "infrastructure of productive systems".. in other words my wife and kids would kill me if there come problems regarding wifi. And as wifi - even of this strange acting satellite - is ok for now i wouldn't wanna bother with it.
Jan 19, 2022Guru
Of course, up to you.
