Bigpopman
Jun 05, 2022Aspirant
Starlink rectangle dish with a Ethernet adapter works with earlier Orbi products
Any luck with this? My Starlink rectangle dish with a Ethernet adapter works with earlier Orbi products, but not the 960. Should I return the 960’s or is there a solution? What newer Orbi’s work w...
- Jun 06, 2022
Something I got from NG support. Would be interesting to know if the suggestion worked.
Jun 06, 2022Guru - Experienced User
I would contact StarLink and see if there modems are compatible with external routers.
Ask if there is any special configurations, i.e. DHCP or PPPoE or VLAN configurations that are needed.
For ISP modems with built in routers:
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Bigpopman
Jun 06, 2022Aspirant
Thanks for the accurate GENERAL info. What I need is specific help with Starlink. Starlink is not able to be configured in the way you have suggested.
