Bigpopman
Jun 05, 2022Aspirant
Starlink rectangle dish with a Ethernet adapter works with earlier Orbi products
Any luck with this? My Starlink rectangle dish with a Ethernet adapter works with earlier Orbi products, but not the 960. Should I return the 960’s or is there a solution? What newer Orbi’s work w...
- Jun 06, 2022
Something I got from NG support. Would be interesting to know if the suggestion worked.
Bigpopman
Jun 06, 2022Aspirant
Thanks for the accurate GENERAL info. What I need is specific help with Starlink. Starlink is not able to be configured in the way you have suggested.
Jun 06, 2022Guru - Experienced User
Something that ISP needs to work on then.
Try option #2 suggestion...
Try AP mode on the 9 series?
- FURRYe38Jun 06, 2022Guru - Experienced User
Ok, NG has said that since this is a StarLink issue, try setting a static route on the RBR for 192.168.100.1
Also need to ensure that the ip address for the Starlink is not on the same network as their other devices. Since the Starlink address will not change then in some cases they will need to change the third octet of their current dhcp server.
Let us know if this works.
- BigpopmanJun 06, 2022Aspirant
I boxed the unit for a return (having 8 hours into this is enough). I unboxed and tried the static IP. No luck. Returning to Netgear. Bummer it does not support Starlink, since its older Orbi's work great.
I am back to my Orbi RBR20 and Starlink which works great, with no special set-up.
This is a Netgear issue. I will look for a different brand because I need better company support (this forum has been helpful, not the company) and it should be easer.
Would have been nice to know if the suggestion had worked.
Good Luck.
