Bigpopman
Jun 05, 2022Aspirant
Starlink rectangle dish with a Ethernet adapter works with earlier Orbi products
Any luck with this? My Starlink rectangle dish with a Ethernet adapter works with earlier Orbi products, but not the 960. Should I return the 960’s or is there a solution? What newer Orbi’s work w...
- Jun 06, 2022
Something I got from NG support. Would be interesting to know if the suggestion worked.
Bigpopman
Jun 06, 2022Aspirant
I boxed the unit for a return (having 8 hours into this is enough). I unboxed and tried the static IP. No luck. Returning to Netgear. Bummer it does not support Starlink, since its older Orbi's work great.
I am back to my Orbi RBR20 and Starlink which works great, with no special set-up.
This is a Netgear issue. I will look for a different brand because I need better company support (this forum has been helpful, not the company) and it should be easer.
Jun 06, 2022Guru - Experienced User
Would have been nice to know if the suggestion had worked.
Good Luck.
