z8
Oct 24, 2021Guide
Status/Firmware Upd shows 1 Satellite - but there are 2 connected
I have a RBK853 system (two satellites). One is wired, one is wireless. On the main page it says I have one satellite (the wireless one) and when I try and check for new FW it only shows one, but...
- Oct 31, 2021
That didn't help, but thanks for the suggestion - it made sense to test that.
In the end (in desparation) I factory reset the whole thing - satellites, main router, the lot.
And now it works.
z8
Oct 24, 2021Guide
- z8Oct 24, 2021Guide
This only happens when it's wired.
If I disconnect the hard wire and connect it wirelessly, then there's no problem at all and it shows two devices.
- FURRYe38Oct 24, 2021Guru - Experienced User
Is the wired RBS directly connected to the back of the RBR or is there a LAN swtich in between the RBR and RBS?
There's a switch - but there always has been.
I switched the main device from Router to Access Point, and this has occured ever since.
