tequillakilla
Dec 23, 2021Aspirant
Still connection loses and buffer overflows
In the meantime I've almost got used to the fact that the WiFi disappears for a few minutes every evening, only to return after what feels like an eternity. The fact that I reset the devices to the ...
- Jan 03, 2022
Thanks for the info. This Sagecom is a gateway modem. Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would recommend configuring option #2 for the RBR to ensure it has a good connection to the internet thru this modem.
Hopefully the suggestions witll help as well.
Enjoy. 📡
Dec 29, 2021Guru - Experienced User
Yes, ISP modems can be a factor in seeing some problems. Why we ask this question to better get a idea of what is at the head of the RBR. Please let us know what brand and model the ISP modem is.
Others have reporting having many odd issues with the current released version of FW. You can try this and see if this helps any:
It's only for the RBR. I have it loaded on mine currently and not seeing any problems since I loaded in 10 days ago.
Someone posted this as well for both RBR and RBS. I have not had a chance to load and try it out yet:
tequillakilla
Jan 03, 2022Aspirant
Since there is unfortunately no fiber optic cable in my street, I use a gigabit connection via my cable provider. He made the SAGEMCOM F @ ST3890 V3 BBN available to me. I deactivated the built-in WLAN and only use this device as a converter from antenna cable to Ethernet, as well as for landline telephones. The reliability of the cable provider is very high and I have a problem with it once every three to six months on average. As a rule, this is easy to find out because the WiFi signal is strong but no internet works. A restart of the SAGEMCOM is then sufficient to fix the problem.
With regard to my ORBI RBR850 problem, the system has actually been running without a single dropout since I made the suggested adjustments. Thank you for the valuable information!
I am now curious whether something will change in this situation after 6-8 weeks, that was always the critical mark for a reset to the factory settings.
- FURRYe38Jan 03, 2022Guru - Experienced User
Couple of options,
Enjoy. 📡- tequillakillaJan 04, 2022Aspirant
Thank you very much for the links and the explanations, currently I don't have these problems because my provider discussed with me beforehand how I would like to use the cable connection and the SAGEMCOM is only operated as a cable modem.
Nevertheless, it is good to know and understand that!
- FURRYe38Jan 04, 2022Guru - Experienced User
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemLet us know how it goes...
