tequillakilla
Dec 23, 2021Aspirant
Still connection loses and buffer overflows
In the meantime I've almost got used to the fact that the WiFi disappears for a few minutes every evening, only to return after what feels like an eternity. The fact that I reset the devices to the ...
- Jan 03, 2022
Thanks for the info. This Sagecom is a gateway modem. Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would recommend configuring option #2 for the RBR to ensure it has a good connection to the internet thru this modem.
Hopefully the suggestions witll help as well.
Enjoy. 📡
tequillakilla
Jan 03, 2022Aspirant
Since there is unfortunately no fiber optic cable in my street, I use a gigabit connection via my cable provider. He made the SAGEMCOM F @ ST3890 V3 BBN available to me. I deactivated the built-in WLAN and only use this device as a converter from antenna cable to Ethernet, as well as for landline telephones. The reliability of the cable provider is very high and I have a problem with it once every three to six months on average. As a rule, this is easy to find out because the WiFi signal is strong but no internet works. A restart of the SAGEMCOM is then sufficient to fix the problem.
With regard to my ORBI RBR850 problem, the system has actually been running without a single dropout since I made the suggested adjustments. Thank you for the valuable information!
I am now curious whether something will change in this situation after 6-8 weeks, that was always the critical mark for a reset to the factory settings.
Jan 03, 2022Guru - Experienced User
Couple of options,
Enjoy. 📡
- tequillakillaJan 04, 2022Aspirant
Thank you very much for the links and the explanations, currently I don't have these problems because my provider discussed with me beforehand how I would like to use the cable connection and the SAGEMCOM is only operated as a cable modem.
Nevertheless, it is good to know and understand that!
- FURRYe38Jan 04, 2022Guru - Experienced User
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemLet us know how it goes...
