OrbiStopped
Jun 16, 2022Aspirant
Still no fix for router login
Original post https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/NETGEAR-is-rolling-out-a-fix-for-an-issue-affecting-the-Orbi/td-p/2226436 I've tried re-starting with no fix. Can Net...
Jun 17, 2022Guru - Experienced User
Did you try factory resetting?
- OrbiStoppedJun 17, 2022AspirantNo. If you read the article, they are supposed to be rolling out a fix that doesn’t require blowing up your system.
- plemansJun 17, 2022Guru - Experienced User
Yes they are. But if its not to your system yet (limited rollout) and you're wanting to fix it, many used the factory reset option in the article.
