ant
Sep 26, 2022Prodigy
Still use WPA2 when Orbi is using WPA3 with old wifi devices?
Hello, Can I use still connect old wifi devices that can't do WPA2 if I set my updated Orbi 753's wifi security to WPA3? Or do I have to use WPA2? Thank you for reading and hopefully answerin...
Sep 26, 2022Guru - Experienced User
WPA3 is supposed to be backwards compatible but usage has shown that not all are.
I turned on strict wpa3 and only had 1 device that didn't work. So I used mixed wap2/wpa3 mode.
Try it and see if they all connect. You might be fortunate and have all your devices work fine.
