ant
Sep 26, 2022Prodigy
Still use WPA2 when Orbi is using WPA3 with old wifi devices?
Hello, Can I use still connect old wifi devices that can't do WPA2 if I set my updated Orbi 753's wifi security to WPA3? Or do I have to use WPA2? Thank you for reading and hopefully answerin...
Sep 26, 2022Guru - Experienced User
My understanding of wpa3 (could be wrong) was that there is a transition period where some wpa2 devices will still connection as long as the manufacturer included the updates to allow it. But that it'll be pulled for strict wpa3 devices at some point. If the device was made before the wpa3 code was released so device makers could update their wpa2 device, then it might not work.
Again, my testing has had my wpa2 devices connect to wpa3 network where most worked. And that wasn't using mixed mode.
Possible device Mfrs had made some improvements. This would have to come from the WPA community and the devices Mfr side though. And with the bazillion devices out there, hard to say. Hoping for the sake of making things easier, would be great if NG just implemented Mixed modes on there routers.
- antSep 26, 2022Prodigy
FURRYe38 wrote:Possible device Mfrs had made some improvements. This would have to come from the WPA community and the devices Mfr side though. And with the bazillion devices out there, hard to say. Hoping for the sake of making things easier, would be great if NG just implemented Mixed modes on there routers.
So, Orbi can't have both WPA2 and WAP3 at the same time? Or did I miss that option in the router's https://192.168.1.1?
- FURRYe38Sep 26, 2022Guru - Experienced User
The 9 series has mixed mode WPA2 and 3. Orbi 7 and 8 don't. We've asked about it. Will keep asking.
