Drewligarchy
Sep 02, 2022Aspirant
Strange Control Panel Behavior for Orbi 6 and 6E
Hi All - I have been going back and forth between Eero and Orbi systems for the past couple of years - and my Eero 6s started dropping connections constantly, and troubleshooting didn't fix the i...
- Sep 02, 2022
Orbi is in AP mode. Araknis is the DHCP server.
Not necessarily asking for help to try to fix the behavior. Instead, asking this:
If my system is still working exactly as if the satellites ARE connected, does it really matter if they show up in the control panel? Am I potentially missing out on any functionality other than having to update firmware individually?
Thus far, it seems I am not. As mentioned, wifi clients switch when they are supposed to - and speeds are as expected Wired and Wireless from the satellites. It's just the control panel. But I am not knowledgable enough about the Orbi software/hardware to know if I am missing out on something else.
Drewligarchy
One more important point:
The Araknis is the DHCP server - and the Orbi is in AP mode.
From Araknis - I am getting the following internal IPs:
RBR: 192.168.2.50
RBS1: 192.168.2.95
RBS2: 192.168.2.77
Interestingly, in the orbi control panel, not only do the satellites not show up - but the IP addresses for the satellites don't either (as a generic device or something) - but they are clearly on the network.
Sep 02, 2022Guru - Experienced User
