devdeep
Jun 25, 2021Guide
Strange internet behaviour
Am using Orbi AX 3 pod system for a couple of weeks now. I have noticed that once a day I loose the internet connection. I have noticed this on my iPad (WiFi) and on my PC (ethernet wired to the main...
devdeep
Jun 26, 2021Guide
RBR 353
v4.3.4.8_1.9.53
Virgin media Hub 3 (359mbps)
40ft or so between RBR and RBSx2
I have the PC linked to the RBR via ethernet (distance og 1.5m
Nothing else causes issues except internet.
Jun 26, 2021Guru - Experienced User
I'd have your ISP check everything out up to the modem.
Is the RBR in router or AP mode?
The ISP modem has a router built in. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- devdeepJun 26, 2021Guide
FURRYe38 wrote:I'd have your ISP check everything out up to the modem.
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopRBR is not in AP Mode - straight Router mode. VM Modem/Router IS in Modem mode, double NAT is not the issue.
- FURRYe38Jun 26, 2021Guru - Experienced User
is the behavior seen with the modem in router mode and the RBR in AP mode?
