relapse_au
Oct 19, 2022Aspirant
Streaming issues with RBR350 (constant buffering and pixelation) when using Chromecast
I've just set up the Orbi RBR350. I have two satellites and in general most things seem to be okay, but the issue I'm having is that if I stream via Chromecast it constantly keeps buffering and I g...
Oct 19, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is any of the following enabled?
Armor, Smart Parental Controls, or Traffic Meter.
