relapse_au
Oct 19, 2022Aspirant
Streaming issues with RBR350 (constant buffering and pixelation) when using Chromecast
I've just set up the Orbi RBR350. I have two satellites and in general most things seem to be okay, but the issue I'm having is that if I stream via Chromecast it constantly keeps buffering and I g...
relapse_au
Jan 10, 2024Aspirant
Does anyone know anything else I can try? I am on the verge of cutting my losses and just throwing this system in the bin and buying something else.
Jan 10, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is any of the following enabled?
Armor, Smart Parental Controls, or Traffic Meter.
Hard to help you out if you don't give feedback to the question presented...
