Frank__M
Dec 11, 2024Aspirant
Struggeling with new Orbi Set
After a couple of years my good old RBR50 Mesh kit died and I purchased a RBK762 as replacement. So I ended putting up the RBR760 at the same place as the RBR50 and swapped the RBS50 with the RBS760....
Dec 15, 2024Guru - Experienced User
Ya, Seems like the 760P series isn't the greatest. Can contact NG support and see if there maybe any recourse. Other then that, I'd probably get into something different.
DarkNet
Dec 17, 2024Apprentice
I have a 4200sqft house and have been using a RBK853 system (router plus 2 satellites) for the last couple of years without any connectivity or signal strength issues. YMMV but its been ok for me. I have the router upstairs on 2nd floor and the two satellites on the first floor. They control 7 TVs (rarely more than 2 TVs on at a time) and many home automation devices. We have 1Gbps service from Xfinity. I have several IoT devices on a separate SSID.
- FURRYe38Dec 17, 2024Guru - Experienced User
Just curious, whats the system uptime show on your 850 series?
- DarkNetDec 17, 2024Apprentice
Up time has been good with the only downtime being the fault of Xfinity. The Orbi 850 devices we have here have been outstanding. By the way I use the RBR850 in AP mode. I have a different router (pfSense).
Is there a time value seen for the RBR and RBS?
- DarkNetDec 18, 2024Apprentice
I dont know where to look for that.
- FURRYe38Dec 18, 2024Guru - Experienced User
Two places, RBRs web page under Advanced Tab/Internet section/Show stats and router IP address/debug.htm
- DarkNetDec 19, 2024Apprentice
I powered down the system a month or so ago for some re-cabling.
- Frank__MDec 19, 2024Aspirant
So, how does the 770 compare?
is that also a cheap'o version? It certainly isn't cheap to buy here...
I am very close to go for a 850.
