JimC_WA
Jun 08, 2022Guide
"Stuttered" speed with AX4200
I have just setup a new AX4200 system that consists of a RBR750 router (firmware: V4.6.5.14) and two satellites (RBS750; firmware V4.6.5.14). Using the Orbi app, I am told my down and upload speeds ...
- Jun 12, 2022
JimC_WA wrote:
Thank you - a good question. I am normally pretty careful updating FW so I'd like to say 'Yes', but I will try again just in case. I assume from your your question, there is no international variation in FW ...? Not that I'm aware of. Same size fits all here.
I should also say, that I did have a Double NAT situation with which I have now fixed and the 'stuttering' speeds we were having have stopped. Hence the initial problem I sought help with has been solved. That said, I am still keen to have the updated FW and will try to resolve that ASAP.
I was wondering about the double NAT thing. Glad thats resolved it.
Hope you can get your system updated gracefully.
JimC_WA
Jun 11, 2022Guide
Thanks for all your help.
Jun 12, 2022Guru - Experienced User
