_Pigpen
Feb 16, 2023Aspirant
Sudden wireless devices speed drop
Hi all, Background: I have a 1Gb/s connection with ethernet straight into my apartment. The apartment is very old and has thick, brick walls and is a stupid shape, so I got an RBR750 and satellite...
_Pigpen
Thanks for the reply.
The speed drop is 'everywhere' whether I am next to the router or satellite or a distance away. I do realise I am beeing 'greedy' and that the speed is fine for every day use. It's just bugging me 🙂
Thanks again
Feb 16, 2023Guru - Experienced User
What modem/gateway do you have?
Are you using any parental controls/qos/Armor?
- _PigpenFeb 16, 2023Aspirant
There is no modem in the apartment. There is fibre to the building and ethernet from a switch to each apartment. Plugging straight into the ethernet port, or into the RBR with ethernet gets expected results of ~900mb/s. Armor is enabled. WMM is enabled on both bands.
- plemansFeb 16, 2023Guru - Experienced User
So the internet is shared between everyone?
It could be a form of QoS on the switch if everyone is sharing the connection.
Or it could be other users saturating the bandwidth.
I'm really not sure how it's dealt with at the ISP switch but I can say that I have never seen a performance dip when using ethernet.
This feels like everything is connecting on wireless N rather than AC/X but the devices are reporting AX. It could be busy channels I guess but there doesn't seem to be much scope for changing channels in the Orbi, is that right?
