Eriksen76
Mar 15, 2025Apprentice
Suddenly a bit lower speeds from router (Orbi 853)
Orbi 853. FW: 7.2.7.15 (Had this issue also with 7.2.6.21) Not sure if there is a problem. Hopefully I explain it understandable as I am not very technical. The recent days I have experienced...
Mar 15, 2025Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
- Eriksen76Mar 15, 2025Apprentice
Thanks I will try to contact my ISP regarding bridge mode.
I already disabled everything regarding wifi in the ISP router. On the display WIFI symbol does not light up either.
Regarding #2. Can't seem to find anywhere to do this:
"configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem."
These are the options I have.
- FURRYe38Mar 15, 2025Guru - Experienced User
Ask the ISP about the DMZ or IP pass thru. Hopefully it has one of those features.
Might give AP mode a try with the ISP rouoter and see if speeds are better...
I tried AP mode now. How do I do if I now want to enter the routers main login?
Can't use the 192.168.1.1 as I normally do?
