mikemike2022
Apr 01, 2022Aspirant
Suddenly I can not access forwarded public IP:port (web site) using Orbi.
Hi friends here I've been using my Orbi RBR750 since last year, and I've set up a port forwarding to expose a hobby website from my PC (192.168.1.123), so for external users, they visit http://publi...
CrimpOn
Apr 01, 2022Guru - Experienced User
mikemike2022 wrote:
However, since the last firmware upgrade, I found myself unable to visit https://public_ip under Orbi's wifi.
The feature involved is called NAT Loopback, and is claimed to work on the Orbi RBR750:
https://kb.netgear.com/000049578/Which-NETGEAR-routers-support-NAT-loopback
It would be a useful experiment to manually load the previous firmware on the router and then quickly test NAT loopback (before the router has a chance to 'auto update' itself. If NAT loopback works as it used to with the previous firmware, then it would seem that Netgear has broken NAT Loopback with the firmware update.
Have you tested NAT Loopback using a device connected to the Orbi with Ethernet?
This issue would not seem to be connected to a possible DDNS problem. It would take more detail to understand that issue.
