Mannaee
Mar 02, 2022Aspirant
Suddenly slow WiFi RBR850
Hi I’m having a weird issue, since i bought the RBS850 and RBS850 before 6 month they were working fine but suddenly since last week the WiFi speed dropped significantly from 500Mb to 180mb without ...
Mar 02, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What devices are you using to speed test with?
Might review this as well:
- MannaeeMar 02, 2022Aspirant
how to find the MFR?
around 1500 sq ft
RBR on the ground floor and RBS on the First Floor, more than 30 feet.
Any Wifi Neighbors nearby? If so, how many?Tried auto and manual (1,6,11). Neighbors wifi is hard to reach since my house and their house are made of concrete also they use different wifi ch than me.
I used Wifi and cable by my laptop and my S22 ultra which supports wifi6
I saw that before but cant risk it using an unstable/verified version which might make my case worst.
FYI, as I mentioned previously This happened suddenly without changing the settings and it was working fine for months. and no issue with the RBS850.
- FURRYe38Mar 02, 2022Guru - Experienced User
Try turning OFF the RBS...and power cycle the RBR.
For that size of home, having the RBS maybe a bit too much wifi. The RBR alone can handle that size of home.
did that before and didn't help
I did another speed test with my phone and I found that if I'm near the RBR within 3 meters i get the full speed, so the problem is more than 3 meters
Depending upon distance and building materials and the device design and support, there can be speed drop off. Great distances you'll not see same speeds while near the RBR. Wired speed should always be consistant.
