Mannaee
Mar 02, 2022Aspirant
Suddenly slow WiFi RBR850
Hi I’m having a weird issue, since i bought the RBS850 and RBS850 before 6 month they were working fine but suddenly since last week the WiFi speed dropped significantly from 500Mb to 180mb without ...
Non-Binary-Bit
Mar 17, 2022Aspirant
Same issue.
Cable modem service is consistently over 200Mbps.
Internet speed test from RBR850 consistently around 230Mbps.
Connections wired into LAN port are over 200Mbps.
All Wi-Fi connections are throttled to about 20Mbps.
Almost as if there is a configuration in the Orbi that is limiting throughput on WLAN.
Also, it’s very curious how the default 90 day support ran out just before this started to happen. Hmm… don’t pay for extended support and you get throttled?
Mar 17, 2022Guru - Experienced User
What devices are you speed testing with?
Non-Binary-Bit wrote:
Same issue.
- Non-Binary-BitMar 17, 2022Aspirant
Firmware Version - V4.6.7.13_2.1.9
Comcast Internet using a Motorola MB7621 (DOCSIS 3.0)
- Bridge Mode. Not double NATed Router is getting public IP direct from Comcast.
Speed Test Results:
Mac directly to CM: ~230Mbps
RBR850 onboard speed test: ~230Mbps
Xbox X ethernet to satelite (RBS850) Wi-Fi 6e meshed to RBR850: ~230Mbps
Any Wi-Fi 2.4Ghz or 5gHz connection: ~20Mbps
- iPhones, iPads, Mac, Samsung S21, Windows PC with SpeedTest, Fast, Speakeasy, and Google across all platforms.
Note: FW was upgraded recently after slow throughput noticed. No improvement after upgrade.
I have professional experience with throttling technologies and this behavior matches to something artificially restricting Wi-Fi connections.
- FURRYe38Mar 17, 2022Guru - Experienced User
Is Armor enabled?
Try setting manual channel 1 and 40.
Set 40Mhz only and try changing CTS to 500 or 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
- Non-Binary-BitMar 21, 2022Aspirant
Update:
Tried all the setting options mentioned and nothing worked.
Tracked down a paper clip (who has these things anymore?) and performed a factory reset. This resolved the issue... temporarily.
I had full speed with the default settings and Armor enabled.
I then disabled WMM from both 2.4GHz and 5GHz. Speed tests went back to 20Mbps.
I re-enabled WMM and the speed went back up to full speed.
This seems like a bug in the Orbi software as disabling QoS prioritization should not artificially throttle Wi-Fi connections by 90%; I would actually expect the opposite.
Unfortunately, the WMM implementation for the RBR850 does seem to also affect wired connections in that my ethernet port connected Xbox X FPS games appear to be negatively affected when someone is running 4K Netflix on a Wi-Fi connected TV in the house. The RBR850 also does not appear to have independent QoS settings or device prioritization options (maybe I'm missing something here).
The default prioritization of WMM is not ideal for >200Mbps connections; especially considering video is buffered and online gaming isn't. Would be nice to have this customizable or maybe device specific.
