jklines
Dec 21, 2021Apprentice
Supposed upgrade from Nighthawk 83 mesh to Orbi RBK82 mesh - Lost Custom WiFi
I thought I would upgrade from an a Nighthawk mesh system to the more expensive Orbi. The Nighthawk has the ability to create a custom 2.4Ghz network for connection of IOT devices. As I'm going throu...
Dec 21, 2021Guru - Experienced User
Orbi doesn't support or have options to separate SSIDs on Orbi systems. If you need separate SSIDs for 2.4Ghz, I recommend you keep the MK system.
