LSCOTTJ71
Apr 21, 2024Aspirant
SWAP SATELLITE FROM RBK753 TO RBK752
HELLO EVERYONE. I HAVE BEEN USING MY RBK752 SINCE JUNE OF 22. ITS COVERAGE HAS BEEN AMAZING. I NEEDED ANOTHER SYSTEM FOR ANOTHER BUSINESS. I PURCHASED A NEW RBK753, THINKING THAT I WOULD NOW HAVE...
CrimpOn
Apr 21, 2024Guru - Experienced User
Yes. Factory Resetting the satellite and connecting it to the existing Orbi router will set the WiFi credentials on the additional satellite to match the Orbi router settings. The "default" WiFi settings that were put in at the factory when the satellite was part of a set will disappear.
How is this satellite connected to the Orbi router? Is it:
- Connecting using WiFi?
- Or, is it 'wired' to the router?
(If it is 'wired', is it connected to one of the LAN ports on the back of the router, or is it connected in some other manner? switches? in-wall wiring? etc.)
LSCOTTJ71
Apr 22, 2024Aspirant
Thank you for verifying the satellite’s preprogrammed settings are cleared out after the reset.
Yes sir, the satellite is connected to the router via WiFi, the same fashion as the original satellite.
Thank you
Thank you
- CrimpOnApr 22, 2024Guru - Experienced User
Please describe the firmware release number running on the router and each satellite.
On the router web interface, this appears in the upper right of most web pages. The Firmware Update menu shows the current firmware on both router and satellites.
The Orbi 'app' describes firmware under "Details".
- LSCOTTJ71Apr 22, 2024AspirantFirmware
Router V4.6.14.3
Original satellite also. V4.6.14.3
New satellite V3.2.15.30
And there in lies a potential problem. The new satellite states there is an update available. I ran it and it says update successful, however it is not successful as it has not updated- CrimpOnApr 22, 2024Guru - Experienced User
It may be possible to manually update that satellite, either using the Manual Update tab on the Firmware Update page or by connecting a web browser directly to the IP address of the satellite.
The RBS firmware can be found here:
https://kb.netgear.com/000065416/RBR750-RBS750-Firmware-Version-4-6-14-3
Should point out that Netgear has released even newer firmware for the 750 series.
https://kb.netgear.com/000066099/RBR750-RBS750-Firmware-Version-7-2-6-31
I have installed it with no problem, but my situation is very "plain vanilla".
