savagebeast
Jun 27, 2023Aspirant
Swapping out RBR850 for RBR40
All; I currently have a RBR850 with three satelittes and an Arris S33 router (about a year old). Xfinity have replaced the line and still around 3-4 times a day my internet connection drops (both in...
savagebeast
Does the top ring on the RBR850 turn PINK when this happens? Not that I have seen; its two floors away however.
Does this happen with the RBS turned OFF? No all of my satelites are on.
What Firmware version is currently loaded? #sv4.6.14.3_2.3.12
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Arris S33 DOCSIS 3.1
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. Yep
What is the size of your home? Sq Ft? s2800 sq ft
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected. 40-50 sq ft
What channel configurations are currently set on the router? Not sure how to check
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update? Yep
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? no given the effort and worried i am not sure if its the Arris or Orbi system
Jun 27, 2023Guru - Experienced User
savagebeast wrote:
Does the front LED on the RBR850 turn PINK when this happens? Not that I have seen; its two floors away however.
Turn OFF the RBS and see if this happens with only the RBR online.
This version is not valid for a RBR50 or 40 series RBR. Please confirm the FW version or the RBR model#.
For this size of home, a RBR and just one RBS is only needed.
Look at the RBRs web page under Basic Tab/Wireless settings.
What channels are you using?
Has a factory reset and setup from scratch been performed since last FW update? no given the effort and worried i am not sure if its the Arris or Orbi systemWould need to try this as last resort.
