Theviewer1985
Aug 18, 2023Aspirant
Switch > Orbi Router AND satellite problems
Hi Please see attached screenshot of my current setup. Using Orbi 850's Note that the upstairs switch is basically unused. I am using the wireless backhaul to connect my Satellite to the Orbi...
- Aug 18, 2023
The switch should come after the Orbi router, not between the ISP device and the router:
Theviewer1985
I had a brainwave as I got into bed. I remember the ISP engineer saying something about the internet flow starting in the downstairs cupboard then goes upstairs before it comes down into the living room.
My RBR in in the living room. My RBS is upstairs.
Tomorrow I will just swap them and see if that sorts the issue out.
Aug 18, 2023Guru - Experienced User
As long as the RBS gets connected BEHIND the RBR, then it will work. Otherwise it won't.
Look at the cabling path.
