theImperator
Sep 15, 2021Follower
Switch compatible for Netgear Orbi WiFi 6 RBR350 Dual-Band Wi-Fi 6 AX1800
Hello,
What types of switches are compatible with "https://www.netgear.com/fr/home/wifi/mesh/rbk353/" ?
Thank you
Any gigiabit switch, from any vendor. There have been concerns in the past about using managed switches to connect satellites to Orbi routers over ethernet. I have not read similar concerns regarding this particular product, but there seems to be no advantage in paying more for a managed switch when an unmanaged switch will function just as well.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
theImperator wrote:
Hello,
Thank you
Netgears GS 1 series are.
theImperator wrote:
Hello,
Thank you
