Obiwanfiobi
Apr 06, 2023Follower
Switch for Orbi AX1800
Hi can I use a ethernet switch with this model wifi6 router? I'm not technical-minded so is there any specs I need to tell the electronic store?
Apr 07, 2023Guru - Experienced User
Yes,
NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
Be sure to use good quality CAT6 lan cabling.
