Serranopr's avatar
Jan 30, 2023
Switching from wireless backhaul to wired on last satellite--proper reboot process?
I've got an RB853 series (router + 2 satellites) running for the past year.  Comcast GigE service, all working fairly well albeit for a few devices that occasionally drop from the 2.4G network with n...
  • CrimpOn's avatar
    Jan 30, 2023
    "proper?"  hmmmmm.
    If wired backhaul is going to work, the satellite will simply switch over on its own.  Nothing needs to be powered off.
    Because this is a new cable installation (which means the connection will consist of:
    • A patch cable from the router to patch panel (two plugs)
    • Cable inside the walls (two jacks - one on each end)
    • A patch cable from the wall to the satellite (two plugs)
    There are several places where "something might be perfect" and the satellite will not switch over to wired backhaul.
    If that happens, most people would temporarily relocate the satellite to be near the router and connect them with a patch cable.  This will validate that the satellite will indeed switch if the cable pathway is correct.
