Serranopr
Jan 30, 2023Tutor
Switching from wireless backhaul to wired on last satellite--proper reboot process?
I've got an RB853 series (router + 2 satellites) running for the past year. Comcast GigE service, all working fairly well albeit for a few devices that occasionally drop from the 2.4G network with n...
- Jan 30, 2023
"proper?" hmmmmm.
If wired backhaul is going to work, the satellite will simply switch over on its own. Nothing needs to be powered off.
Because this is a new cable installation (which means the connection will consist of:
- A patch cable from the router to patch panel (two plugs)
- Cable inside the walls (two jacks - one on each end)
- A patch cable from the wall to the satellite (two plugs)
There are several places where "something might be perfect" and the satellite will not switch over to wired backhaul.
If that happens, most people would temporarily relocate the satellite to be near the router and connect them with a patch cable. This will validate that the satellite will indeed switch if the cable pathway is correct.
CrimpOn
Jan 30, 2023Guru - Experienced User
"proper?" hmmmmm.
Serranopr
Jan 30, 2023Tutor
Great--it will be a dedicated patch cable running up in the attic and down into the router through a wall pass through, and at the satellite also through a wall pass through. Direct connection without using keystone jacks and additional patch cords.
I tried to look at the documentation and see if it was as simply as plug and play, and glad to hear that is the case. The previous wireless backhaul will see a new wired connection and default to that mode.
