SaintBreesy09
Jan 21, 2022Guide
SXK80 (SXR80 Router and SXS80 Satellite) compatibility with any other Orbi units (new or old)?
Did a thorough search I thought to figure out if ANY other Orbi satellites could mesh with the system I have for my at home business (SXK80) and came up dry. I'm particularly interested in possibly a...
- Jan 21, 2022
Correct. There is a world of difference between devices which are designed to move and those which remain in place.
For example, suppose there is an IoT device that does not get good coverage (garage door opener, irrigation controller, exterior camera, doorbell, etc.) 99% of IoT devices are 2.4G WiFi and require modest bandwidth. An expensive WiFi extender, such as a TP-Link N300 (under $20US) or a Netgear EX3700 (under $40US) can be placed where it gets a decent signal from an Orbi unit, but is closer to that needy device. For the "extension", choose a different WiFi SSID, such as "<orbi-name>-ext1" (use "ext2" for the next such device, etc.)
CrimpOn
Jan 21, 2022Guru - Experienced User
More SXS80 satellites can be added, and will provide "seamless" WiFi on all channels (Guest, Employee, IoT, Administration). When placed in a window, there will be a lot of coverage outside, with no need for exterior power and weatherproof enclosure. There have been several posts by users who mounted ordinary Orbi satellites in weatherproof enclosures with great success.
If a seamless network is not essential, then any brand of WiFi extender can be used to expand the coverage area. The (aging) RBS50Y Orbi satellite (outdoor rated), for example, will connect to any brand of WiFi router as a WiFi "extender".
