SaintBreesy09
Jan 21, 2022Guide
SXK80 (SXR80 Router and SXS80 Satellite) compatibility with any other Orbi units (new or old)?
Did a thorough search I thought to figure out if ANY other Orbi satellites could mesh with the system I have for my at home business (SXK80) and came up dry. I'm particularly interested in possibly a...
- Jan 21, 2022
Correct. There is a world of difference between devices which are designed to move and those which remain in place.
For example, suppose there is an IoT device that does not get good coverage (garage door opener, irrigation controller, exterior camera, doorbell, etc.) 99% of IoT devices are 2.4G WiFi and require modest bandwidth. An expensive WiFi extender, such as a TP-Link N300 (under $20US) or a Netgear EX3700 (under $40US) can be placed where it gets a decent signal from an Orbi unit, but is closer to that needy device. For the "extension", choose a different WiFi SSID, such as "<orbi-name>-ext1" (use "ext2" for the next such device, etc.)
SaintBreesy09
Jan 21, 2022Guide
Ok, that is what I was thinking. In order to keep Mesh connectivity, I'd only be able to add an additional SXS80, correct?
If I just wanted to try and "juice" up the external areas a bit I could add the RBS50Y but with the possibility that devices fall-off or just won't continue to mesh to the best satellite connection. This probably wouldn't be a terrible solution given the fact that the cameras are static and don't physically move around...it would just be the things like kids and their phones or other devices that come in and out of the house at a given moment, correct? Am I thinking somewhat accurately along those lines? Thanks a ton for the help and wuick reply!! --Kirk
CrimpOn
Jan 21, 2022Guru - Experienced User
