sbatchik
Jun 23, 2023Tutor
T Mobile Wifi calling issues
Upgraded from Nighthawk RAE500 6E router because of new home. Using the new Orbi 6E Mesh system. On T mobile. Wifi calling worked great before the switch but now it is intermediate at best. Most time...
Jun 23, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Enable SIP ALG on the RBR and try.
Also review this as well:
https://www.surveymonkey.com/r/G32BGFF
