sbatchik
Jun 23, 2023Tutor
T Mobile Wifi calling issues
Upgraded from Nighthawk RAE500 6E router because of new home. Using the new Orbi 6E Mesh system. On T mobile. Wifi calling worked great before the switch but now it is intermediate at best. Most time...
Jun 29, 2023Guru - Experienced User
Any progress on this?
sbatchik wrote:
Upgraded from Nighthawk RAE500 6E router because of new home. Using the new Orbi 6E Mesh system. On T mobile. Wifi calling worked great before the switch but now it is intermediate at best. Most times, people cant hear me. Someone said you need to open ports on the system. Does anyone know which ports need to be open?
TIA
- F_VJun 30, 2023Luminary
WiFi calling ports are 500 and 4500. I had the same problem, opening both of those allowed WiFi calling to work perfectly on both Android and iPhone.
- FURRYe38Jul 01, 2023Guru - Experienced User
I would try and enable SIP ALG on the RBR. It's disabled by default. Been testing with it enabled along with some others. Working with it enabled.
