Starky-50
Jun 01, 2022Aspirant
Take a RBS850 apart, how to do that
I want a manual to remove the cover from my RBS850. One of the mounting points on the bottom has come loose. Does anyone have a description of how to take it apart.
- Jun 01, 2022
That will do.
thnx.
Jun 01, 2022Guru - Experienced User
Look either at the back for front down under where the front white cover meets the front LED, There is a tab on the side on the back of the white cover. Press this towards the cover itself. Then I believe you gently push upwards and the cover should come off.
CrimpOn
There are pictures of the case in the FCC filing for the 850:
https://fccid.io/PY319200453/Internal-Photos/Internal-Photos-rev-Part-1-4433134
- Starky-50Jun 01, 2022Aspirant
That will do.
thnx.
