devdeep
Aug 28, 2022Guide
Telephone connection with Openreach ONT with Orbi353
Will switch over to BT broadband (FTTP available). My current setup is Virgin hub (in Modem mode) and Netgear Orbi Mesh in Router mode off it. I have a copper landline as well. Plan to switch to BT ...
ekhalil
Aug 29, 2022Master
Orbi is still great in AP mode. You will loose some features like parental control, VPN, DDNS, .... but you will still get the same good wifi coverage.
On the other hand, if you want to run Orbi in Router mode, and if you can't bridge the BT / Sky Hubs, will you be able to just set the BT / Sky Hubs to forward traffic to DMZ and disable DHCP? If there is such settings in the ISP router then you will be able to run Orbi in Router mode.
- Wizzard370Aug 29, 2022Tutor
Will look into the DMZ issue. Please explain a bit more on one cannot use VPN. I sometimes use the VPN via Chrome browser - will this be an issue?
- ekhalilAug 29, 2022MasterThe VPN that requires Orbi in Router mode is the Orbi as VPN server. That is you connect from outside your home to Orbi and become as if you’re at home (get an internal IP address from Orbi). Other types of VPN will work regardless of Orbi operating mode.
- devdeepAug 30, 2022Guide
if I configure the Orbi in AP mode, will the WAN port automatically change to another LAN port?
