devdeep
Aug 28, 2022Guide
Telephone connection with Openreach ONT with Orbi353
Will switch over to BT broadband (FTTP available). My current setup is Virgin hub (in Modem mode) and Netgear Orbi Mesh in Router mode off it. I have a copper landline as well. Plan to switch to BT ...
Wizzard370
Aug 29, 2022Tutor
Will look into the DMZ issue. Please explain a bit more on one cannot use VPN. I sometimes use the VPN via Chrome browser - will this be an issue?
ekhalil
Aug 29, 2022Master
The VPN that requires Orbi in Router mode is the Orbi as VPN server. That is you connect from outside your home to Orbi and become as if you’re at home (get an internal IP address from Orbi). Other types of VPN will work regardless of Orbi operating mode.
