KathrynK
Jul 24, 2020Aspirant
Temporarily disable 5 Ghz for Weather Station
AX4200 RBK752 Orbi Mesh Please HOW TO for Dummies How do I Temporarily disable 5 Ghz on my Orbi Mesh AX4200-RBK752 for Ambien Weather Station WS2902A
Bandito
Jul 24, 2020Luminary
Unfortunately, there is no option to do this. The only thing that you can do is reduce the power level of the radios.
- KathrynKJul 24, 2020Aspirant
How do I reduce the power levels?
- plemansJul 24, 2020Guru - Experienced User
You can actually just disable the wireless ssid broadcast for the 5ghz. It doesn't shut down the 5ghz but makes it more like a phone and the weather station will connect to the 2.4ghz.
Advanced---->Advanced setup------>uncheck the enable ssid braodcast for the 5ghz.
You also need to make sure the phone that you use for setup is on the 2.4ghz during the setup process. You might have to disconnect reconnect to get it to associate with the 2.4ghz.
Where do I find this?
"Advanced---->Advanced setup------>uncheck the enable ssid braodcast for the 5gh"
